2004 voyager remote locking issues
Old Mar 25, 2012 | 06:34 AM
tag-uk's Avatar
Default 2004 voyager remote locking issues
i have problem with my 04 reg 2.8 ltd xs, it has the power doors/tailgate, the remote fob wont open the doors or set the alarm the red light on the dash for the alarm isnt illuminated ive tried stuff in posts that ive found on here but still nothing, however the doors will lock using the lock button inside, tested the remote and thats giving out a signal, took to dealer, they say it needs a skim unit?, but isnt the skim unit part of the ignition barrel where the key is, and isnt the remote locking and alarm a seperate entity to the immobiliser, does anyone know where the remote locking receiver/ecu is?, as i have another voyager i could swap with to see if it workss?, cheers in advance matt
Old Mar 25, 2012 | 08:11 AM
- did you in fact try the IOD fuse
- and battery disconnect
- and re-sync the fob / barrel
BTW if you read the thread link above the """lock button inside""" is part of the problem .. .. stop using it !
I'm NE England if I can help M8
Old Mar 25, 2012 | 03:20 PM
tag-uk's Avatar
tried all that how do you re-sync the fob barrel
Old Mar 25, 2012 | 06:27 PM
- all these motors check for 15 minutes for errors before the BUS shuts down !
- doubt ? ... manually switch/leave a rear passenger interior light on and lock & leave !
- it will go out at about 15 minutes, and the car will be armed
The answer is :
- key 'live' in the IGN .. .. or simply start the MOTA
- then lock and unlock the doors from the FOB
- then get out and lock in the usual way
NOTE: the BUS needs to be live to [save to the EEPROM] register the 'pairing' with the Body Module for the next unlock.
Old Mar 26, 2012 | 10:37 AM
tag-uk's Avatar
tried that still with no joy! cheers, as for the light one i cant get out and lock the car unless i do it from the key in the lock!.....
Old Mar 26, 2012 | 11:06 AM
- sorry I can't help M8, maybe a techie will come along with advanced suggestions
- as far as I'm aware the 'remote keyfob receiver' is built into the rear view mirror
Old Mar 26, 2012 | 11:14 AM
PCI Bus message, or coded messages to the SKREEM. If all of the criteria for monitoring a circuit or function are met and a fault is sensed, a diagnostic trouble code will be stored in the SKREEM memory.
3.2.8 SKREES OPERATION
When ignition power is supplied to the SKREEM, the SKREEM performs an internal self-test. After the self-test is completed, the SKREEM energizes
the antenna (this activates the transponder chip) and sends a challenge to the transponder chip. The transponder chip responds to the challenge by generating an encrypted response message using the following:
- Secret Key - This is an electronically stored value (identification number) that is unique to each SKREES. The secret key is stored in the SKREEM, PCM and all ignition key transponders.
- Challenge - This is a random number that is generated by the SKREEM at each ignition key cycle.
goggs
28
Feb 22, 2015 04:52 AM
ntwrkguy1
Dec 5, 2014 07:14 PM
nidges2
May 17, 2014 12:19 PM
sundowners
Apr 22, 2014 03:11 PM
ashnatlucy
Oct 21, 2011 03:32 PM
