2005 T&C, [Video] Is This A CV Joint Going Bad?
Old Nov 20, 2010 | 01:00 PM
GTC12987's Avatar
Question 2005 T&C, [Video] Is This A CV Joint Going Bad?
http://www.youtube.com/watch?v=RuuwbKCf_fQ
I'm guessing my CV joint is going bad. In the above linked video, you can see and hear the noise. The van is parked on a downward slope and I'm shifting between reverse and drive. You can hear an audible, "pop". I'm also getting vibrations in the drive train at about 40 MPH just when the transmission shifts to over-drive. The vibrations go away if I let off the gas, accelerate faster, or drive in 3rd gear. Also, the vibrations are not evident coasting down a hill. Only during light acceleration can I feel the vibrations on only then at 1100 RPM and 40 MPH.
Thoughts?
Old Nov 20, 2010 | 11:15 PM
TNtech's Avatar
That POP you hear is an axle nut that has backed off just a hair. No problem it just happens over time. A few whacks with an impact gun will shut that up. About your vibration, yes it could be a CV joint BUT an out of round tire can magnify any wobble in a front wheel drive under acceleration. My advice would be rotate the tires front to back and see if the condition changes. If not then get you a couple new front shafts. They aren't very expensive.
Old Nov 20, 2010 | 11:33 PM
GTC12987's Avatar
Thank you for the reply. I tested several scenarios like turning the wheel to the left or right and driving in a circle but I heard no other sounds or vibrations. I also tried to twist or shake the axle's with my hand (wheels on the ground) but nothing was lose.
I just put new tires on this week and the pop/vibration was present with the old tires too. I do not have an impact gun so would a ratchet/socket do the trick? And, shamefully, I do not know where the axle nut is but I'm assuming it is the nut visible when I remove the wheel...located at the center of the break rotor's housing?
Thank you for the help.
Old Nov 21, 2010 | 11:49 AM
TNtech's Avatar
Yep, right in the middle. Take the wheel off. You'll need a big breaker bar or you can just ask the tire shop to do it for you. The noise is the hub and the outer CV cup torque stressing against each other. About the vibration from the axles, looseness is not always a symptom. If the joints can't articulate that will cause a vibration too.
dramey86
Jul 13, 2013 01:01 PM
gec
Jun 15, 2012 11:44 AM
jtminnc
Oct 31, 2010 07:08 PM
BIGCJ
Cirrus & Breeze
20
May 27, 2010 05:24 AM
