2005 T&C sunroof fuse - Where is it?
Old Apr 26, 2015 | 09:07 AM
sam devlin's Avatar
Default 2005 T&C sunroof fuse - Where is it?
I just bought a 2005 T&C with the 3.8. The sunroof does not work & I'm trying to track down the problem. The van didn't come with an owners manual & I got a Haynes repair manual from the library but no mention of the sunroof in it. I don't see the sunroof fuse listed in the lid of the under hood fuse box.
So where is that sunroof fuse located???
Is there a know issue with the sunroof switches??
Old Apr 26, 2015 | 01:17 PM
Vmaxxer's Avatar
I didn't even know a sunroof was an option for a Voyager/T&C ..
Old Apr 26, 2015 | 02:14 PM
Power sunroof & adjustable pedals began in 03 depending on options.
Old Apr 26, 2015 | 04:26 PM
Raptor 07's Avatar
I'm seeing two fuses on the diagram. 40 amp fuse #32 off the hot battery bus and 20 amp fuse #11 off the accessory relay both located in the IPM (fuse box).
Old Apr 26, 2015 | 05:22 PM
sam devlin's Avatar
Thank you for the info Raptor 07 but I don't have an owners manual or any way to know where #32 & #11 are located in the fuse box. Can you scan a diagram for me?
Old Apr 26, 2015 | 07:46 PM
The fuse locations are inside [look inside] the lid of the IPM, its possible the sunroof specific fuse is in the IPM, but the sunroof 'pinout' connectors are listed here. Your workhop manuals are here. All the manuals for all the years are here.
- better image here for you
Old Apr 26, 2015 | 09:24 PM
sam devlin's Avatar
Thanks for the info. I'll check it out tomorrow.
Old Apr 27, 2015 | 08:01 AM
sam devlin's Avatar
I'm fully aware that the fuse locations are listed on the underside of the fuse box lid, but there is no mention there of a sunroof/moonroof fuse as I said in my original post. As for that link you sent, maybe you have better eyes than me, but I have looked through it more than once last night & this morning and still haven't seen a mention of the sunroof/moonroof.
I think I'm going to pull the overhead console and see if there is power at the switch. If there isn't back to square one. If there is, I'll check the switch.
Old Apr 27, 2015 | 12:58 PM
royal100805's Avatar
You could try pulling each fuse 1 by 1 to check them for continuity or by eye. You may get lucky.
Old Apr 27, 2015 | 03:03 PM
- that's why I carefully only said possible
- I could find no specific info on the sunroof fuse location for you my friend
- agreed its looks like spark chasing is your next best option, best of luck
