2005 T&C Transmission - Do I have Traction Control?
Old Sep 2, 2022 | 08:37 AM
Jonboy's Avatar
Default 2005 T&C Transmission - Do I have Traction Control?
So my Tranny is having issues…. At 344k miles, I’m not surprised.
I had the engine replaced at ~185k, and am considering replacing the transmission with a junkyard pull.
the only issue is I need to know whether the vehicle has Traction Control….and I’m honestly not sure.
How do I find out?
Below is the VIN # if that helps. I plugged it into a couple of VIN decoders and have gotten mixed results…2C8GP64L85R433563
and….do I HAVE to get a transmission that has Traction Control? If I don’t have to, but the vehicle came with it, what does that really mean for me electrically/mechanically? Obviously I know it means I won’t have that feature, but how big of a deal is it aside from that?
Thanks!
Jonboy
Old Sep 3, 2022 | 10:34 AM
Traction control is in the ABS brakes not transmission if you have trac control there will be a button on you dash to turn it on and off.
Old Sep 4, 2022 | 07:44 AM
Jonboy's Avatar
i understand that, but for some reason the website I am looking at for getting a new transmission makes a distinction, which also affects the price. As soon as you put in the year, make, model, and that you want a transmission, you are prompted not only for the engine size, but also whether the vehicle has traction control. I’m trying to understand why that matters? If I change the year model to 2006, I am only asked for the engine size….
https://autoenginesoutlet.com/store/...4f79&seq_num=4
thanks,
Jonboy
Old Sep 7, 2022 | 09:42 AM
user 7698720832's Avatar
Be aware if you change the transmission you will (I believe) also have to either reprogram or replace the transmission control module?
indysebring
May 30, 2019 07:49 AM
indysebring
May 29, 2019 02:56 PM
sebring09
May 21, 2011 08:53 AM
tcoxcsr
Jun 23, 2008 08:07 PM
F150
Mar 15, 2007 12:13 AM
