2006 T&C electrical issues
Old Aug 9, 2013 | 02:20 PM
volly's Avatar
Default 2006 T&C electrical issues
My 2006 is starting to have "issues" - one day about 3 months ago the key-less entry and the tire pressure sensor system stops working. A week later the key-less system starts working again but to this day the tire pressure system is still dodgy. Last night while driving down the motorway my headlights started flickering. I managed to get where I needed to go but I'm at a loss as to what is causing all of this.
I was going to start by doing the following:
1. unhook the battery
2. unplug, inspect, clean if needed then reconnect each connection (one at a time) in the engine compartment then everything under the dash that I can reach.
I figure this will take me most of the day to do. Any pitfalls I need to be aware of? I won't unplug more than one item at a time.
Old Aug 9, 2013 | 04:24 PM
Raptor 07's Avatar
It would be great to be able to say these are all related. If they are it's a good bet there's a problem in the IPM/FCM area. That's the fuse box and the silver box bolted to the front of it. The combination have been a historical trouble spot for Chrysler minivans. The FCM is suspect especially relative to the headlights, specifically the poorly designed connection between it and the IPM. Might try to tap/wiggle/shake everything in that area including the wire harness to the bottom of the IPM.
Then there's this: Chrysler guarantees minivan headlight switches | Business & Technology | The Seattle Times
ikappa
May 23, 2022 04:44 PM
Pebbleskn11
Mar 4, 2014 06:35 PM
Rasta4i
Jan 12, 2014 01:54 PM
privat12
Jul 14, 2013 01:05 AM
chryslervan
Mar 16, 2009 07:02 PM
