2006 T & C- no fuse for washer
Hey Gentlemen, I haven't had my washers working, don't know if they ever did. But I went to check the fuse and not only is there no fuse (15A), but there isnt even a metal clip FOR a fuse? What gives? Is it possible the holder fell through the back and I have to pull the fuse block? Please let me know. I know I checked the right one but there is nothing there but a slot, no clip.
No washers, no fuse, no holder for fuse. The big question is, have you really got a car.
Not a car.....a van. Seems like a Senior Member would know that.
that model the wipers and lites and few other items are control by the front control module
Thanks for the reply
Could you please be more specific...location in fuse box? As far as I know, no other devices are affected. ...will double check.
Fuse box is called an IPM, and looks like this it holds these components. Its next to the battery in the EURO cars RHD, so I assume next to the battery in yours. Your washer fuse should be #6 I think - why there's no fuse holder for it - I've never seen one - put a photo up here and we will try and help !
EURO Vans QinteQ you should know better...
Originally Posted by goggs
(Post 92158)
I'm no mechanic but.....
I did a little research and found others with the same problem. That said, I believe that the washer pump HAS NO FUSE. It is directly powered from the "IPM". Others on the net have been stumped too because the fuse box clearly has a place for the fuse but NO FUSE! Anyhow, after removing the pump which is fairly easy, I decided just to take it to the parts store and pay $40 for a new one which I will install tomorrow. It could be something else but I will take a chance on a new pump.
just a note, you can get these all day on Ebay for half that cost if you don't mind waiting for it...just saying. I will update after install and give you the answer on the repair.....fingers crossed. |
Thanks for the update Eddie A. Steiner
