2006 T&C Touring, Moldy Smell
Old Jan 1, 2009 | 11:04 AM
psueric's Avatar
Default 2006 T&C Touring, Moldy Smell
I've got a 2006 T&C Touring Edition, and whenever it sits for a few days, Especially if there's rain, I get a musty/moldy smell in the cabin. It doesn't depend on the Heat/AC running.
It seems to me like there's standing water somewhere accumulating somewhere, and I'm looking for a clue where I should start my search.
Thanks for your help
-Eric
Old Jan 1, 2009 | 09:39 PM
Al B's Avatar
Default RE: 2006 T&C Touring, Moldy Smell
Still under warranty?
Old Jan 2, 2009 | 07:48 AM
psueric's Avatar
out of warrenty by about a month
but it might be worth a try, asking the dealer.
they might be willing to make a good faith attempt...
Old Jan 2, 2009 | 09:30 AM
JeepAndAVan's Avatar
check the floorboards under the carpet on the passenger side under the carpet and insullation...is it wet under there?
Old Jan 14, 2009 | 04:20 PM
psueric's Avatar
I've checked the carpet and insulation throughout the cabin, and everything seems dry.
Old Jan 14, 2009 | 04:53 PM
Rick99's Avatar
Don't rule out the HVAC system too quickly. If the drain is clogged, you could be building up mold. It could also be growing in the evaporator. Have you changed your cabin air filter recently?
Old Jan 15, 2009 | 12:16 AM
dodgetech1's Avatar
Don't really see any leaks on this i would just check all the drain hoses on it, espeacially the ones on the cowl.
Old Dec 25, 2009 | 05:16 PM
actd's Avatar
I've had this problem on my 2001 Voyager - was worst when it was raining, or when I used the windscreen washers, so looked like it was water going into the air inlet below the windscreen. I solved the problem by spraying a bacterial spray into the air inlet to kill anything off in there, but I assume that there is something growing, and possibly drain holes are blocked. Can someone tell me where I need to look for the drain holes to clear them out?
curlybird74
Mar 10, 2014 03:00 PM
scott04
Dec 3, 2008 07:34 AM
nauman
Jul 26, 2008 03:42 PM
zolazoey
Jan 15, 2008 08:27 AM
TandC Troubles
Dec 10, 2007 08:35 AM
