2007 voyager alarm issue
Old Jul 9, 2017 | 03:05 AM
yableep's Avatar
Default 2007 voyager alarm issue
Hi to all of you,
Iam in need of some help or advice about factory fitted alarm system.
Basically I have an issue with the fob not switching off the alarm.
I have to reset the alarm by disconnecting the battery, reconnecting and set to run mode with the key.
I works okay for a couple of days and it does the same again.
I wonder if the module regulator is at fault.
If I would change the regulator, does the new modulator needs programing?
Also where is the regulator located?
Thank you
Old Jul 13, 2017 | 10:29 AM
Vonhofinvule's Avatar
I had it happen on my 98 GV and my cousin had it happen on his 2004. He just left his disconnected by I replaced the actual sounder unit which is located under the left hand headlamp with a one from the junk yard. However, although this did cure my issues it only lasted for about 7 months. I switched it out again and again it worked for a while but when it failed again I just left it disconnected.
Old Jul 13, 2017 | 04:29 PM
yableep's Avatar
Default Thanks for your reply
How did you found out that it was the siren unit?
Did you just unplugged it in the end?
Old Jul 17, 2017 | 10:58 AM
I'd had a similar problem a few years ago with a Jaguar and had tried it on that car with a spare I had sitting around. So when my GV began having a similar issues I thought it would be worth trying. And yes I simply unplugged it.
Old Jul 17, 2017 | 04:10 PM
yableep's Avatar
Default voyager alarm issue
Thank you
Old Jul 29, 2017 | 04:42 AM
yableep's Avatar
do you know whwrethe backup battery is located, mine is a twin horn and not a single where the battery is inside.
scoobs2
Aug 31, 2010 03:42 PM
bigw1231
Mar 12, 2009 10:01 PM
dmlover76
Cirrus & Breeze
Apr 20, 2008 12:43 AM
lebrund
Sep 6, 2007 08:05 AM
mrrbby
Jan 13, 2007 03:49 PM
