2008 stereo issues
Hello, I am currently on vacation and had to boost my van due to a cooler left running overnight by accident. Since the boost, I have not had any power to the stereo/back up camera screen. I have checked the fuse panel and found only the M10 fuse that has any possible connection to the unit but the fuse is sound. My VES system seems to work just fine. I'm wondering if there isn't maybe a secondary fuse panel inside the vehicle that I cannot find? Any helpnwould be greatly appreciated!
Cheers!
Cheers!
Thanks again for your input!
G
If the fuse to your radio is bad you'll see other symptoms. Take your battery terminals off and touch them together for about 15 minutes. You may need a rubber band or something. Let me know what happens.
I forgot to come back here to update! I took out all relevant fuses to the system and re-seated them, got under the dash and made sure all wiring was snugged up and not loose, put the key in and started the vehicle and she came to life! Not sure what was the issue but the good news is she is fixed! I appreciate your assistance sir!!
patmanandbobbin
Oct 10, 2011 10:19 AM
