2008 T&C MyGig display screen messed up with lines & dots
Old Mar 2, 2008 | 10:14 AM
Loki Sunrider's Avatar
Default 2008 T&C MyGig display screen messed up with lines & dots
Sometimes the MyGig display screen gets messed up with lines and dots all over it, like the display
is going bad.
I believe this happens when the key-fob is not pushed all the way into the ignition or it is tilted a bit
in the ignition. There is some kind of interference.
Once you push the key-fob all the way inside the ignition and straighten it out the MyGig display screen
corrects itself and goes back to normal.
Hopefully Chrysler will have a recall on this and fix the ignition slot to hold the key-fob better.
Don't forget, Chrysler, we typically have 2 - 6 other keys dangling on the other end of our key-fob
which add up to a couple of ounces of counter weight!!
Thanks and see you out there,
Loki Sunrider
CharlieHigh
Nov 21, 2017 06:21 PM
Mongolchuck
Mar 26, 2015 08:12 AM
Beck
Aug 20, 2013 03:08 PM
Gary25
Mar 3, 2012 10:18 AM
ARMY DOC
Jun 8, 2011 08:32 PM
