2008 T&C power doors wont work with handles outside
Old Feb 8, 2017 | 06:14 PM
tipsy's Avatar
Default 2008 T&C power doors wont work with handles outside
2008 town and country both L & R power sliding doors won't power open with the outside door handle. They will open by manually pulling the door or under power with a FOB, door jamb switches or overhead switches.
Any ideas??
Old Feb 8, 2017 | 08:15 PM
georgef's Avatar
Chrysler vans didn't have that feature until the 2009 model year.
From the 2008 owners manual:
POWER SLIDING SIDE DOOR — IF EQUIPPED
The power sliding door may be opened manually or by using the buttons on the Remote Keyless Entry (RKE) transmitter.
Press the button on the transmitter twice within five seconds, to open a power sliding door. When the door is fully open, pressing the button twice within five seconds a second time will close the door.
There are also power sliding side door switches located on the trim panel just in front of the power sliding door for the rear seat passengers. Pressing the switch once will open the power sliding door. When the door is fully open pressing the switch a second time will close the door.
From the 2009 owners manual:
Power Sliding Side Door — If Equipped
The power sliding door may be opened or closed manually or by using the buttons on the RKE transmitter, overhead console switch, or rear door switch. Pulling the inside or outside power sliding door handle will also power open or close the power sliding door. NOTE: Pulling the outside power sliding door handle a second time while the sliding door is power opening or power closing will allow the sliding door to be opened or closed manually.
Press the button on the RKE transmitter twice within five seconds to open a power sliding door. When the door is fully open, pressing the button twice within five seconds a second time will close the door.
There are power sliding side door switches located on the trim panel just in front of the power sliding door for the rear seat passengers and in the overhead console for the driver and passengers. Pressing the switch once will open the power sliding door. When the door is fully open pressing the switch a second time will close the door.
Old Feb 9, 2017 | 06:48 AM
tipsy's Avatar
Thanks! It was a bit confusing when it said "opened manually". Appreciate the clarification. I've had several vans of various brands and years that did power open with the outside handle so I was expecting it.
Dylan Galvan
Apr 17, 2012 03:11 PM
mifirecop
Jan 9, 2012 07:30 AM
15951a\
May 6, 2009 10:58 AM
mailmule
May 2, 2009 02:31 PM
tmorales509
Aug 2, 2007 04:00 PM
