2008 T&C stalling, rough idle, hesitation
Old Apr 12, 2015 | 08:09 PM
  #21
StratLou's Avatar
Originally Posted by royal100805
I think you should do a full service first;
Air filter, fuel filter, oil & filter, spark plugs. If this has helped but still not 100% then replace the coil packs. At least you now know you have a good base to start from with further fault finding and knowledge that your engine should be in a better state of health.
The air filter was done recently, oil and filter done today, the fuel filter is apparently part of the fuel pump setup and is in the tank. Cost $300+. I'll need to pass on that one until signs point to it more definitevely. I'm leaning towards the plugs and/or coil pack(s). As per the maintenance schedule, the plugs need to be changed at 102,000 and we're at almost 99k. So maybe this is the time for those and see what happens. Then I can go from there.
Old Apr 19, 2015 | 02:59 PM
  #22
Any result from this fault Stratluo....
Old Apr 20, 2015 | 12:25 PM
  #23
StratLou's Avatar
If you mean the plugs, no. Haven't gotten to them yet. I also have to do same on my Ford pickup as it is in the same time period for plugs (and coolant, timing belt, etc., on the van). Too much all at once at this maintenance period.
Old Apr 20, 2015 | 04:01 PM
  #24
mrfixit's Avatar
Information on your car required.
Old Apr 20, 2015 | 04:21 PM
  #25
mrfixit's Avatar
If you have ANY ignition issues you WILL have codes. something is going on that the PCM does not monitor. what you may say. fuel injectors. try some good fuel injector cleaner and oh don't forget some dry gas. these systems don't like water. an engine temp sensor will do one of two things. if it tells the pcm your engine is warm when it is actually cold it won't start without some coaxing and will not set a code because the PCM sees this as normal. but if it shows it is cold like -40 all the time the PCM will set a code because it wants to see a temp change in a pre determined time frame so temp sensor is out. do the dry gas and cleaner thing and go from there, much cheaper then throwing parts at a problem.
Old Apr 20, 2015 | 08:43 PM
  #26
StratLou's Avatar
Makes good sense and I will add these to the to-do list for our problem. Any thoughts, from the symptoms the vehicle has been experiencing, as to whether throttle body cleaner and/or MAF sensor cleaner may help solve the problem as well or would they be a waste of time and money in this case. Thanks.
Old Apr 21, 2015 | 09:19 PM
  #27
mrfixit's Avatar
Your not supposed to clean the mass air flow sensor. throttle body/carb cleaner is used to clean the throttle plate of gunk for ratty idle. seeing your throttle plate is partially open under normal conditions this would not apply.
Hope this helps.
Old Apr 22, 2015 | 12:57 PM
  #28
StratLou's Avatar
Here's a video link to perform this function. Don't think I need to do it for our van as we've always kept up with the a/f replacement schedule and haven't thrown a check engine light either.
Old Apr 22, 2015 | 05:52 PM
  #29
georgef's Avatar
Your van doesn't have a MAF sensor, it uses a MAP sensor to performs a similar function.
Old Apr 23, 2015 | 10:44 AM
  #30
mrfixit's Avatar
CRC Mass Air Flow (MAF) Sensor Cleaner Instructional Video - YouTube
You can do what ya want. i am just saying what i was taught at training center. mass air flow sensors do not require any cleaning and besides this will not cause an engine to miss and carry on.
