2009 T&C limp mode after replacing TIPM
Old Jan 1, 2018 | 10:20 PM
Nd48463's Avatar
Default 2009 T&C limp mode after replacing TIPM
I've been battling my van for 2 weeks now. Last month I replaced the trans solenoid pack to fix limp mode problems due to bad solenoid. This fixed tge problem and the van ran great for about a month. A month later I had a no crank/no start issue. I ended up replacing the starter, battery, and TIPM and still no start. I then found the mesh ground had corroded and broke. I added a new motor to body ground on both sides of engine and finally got the van to start. It runs great upon first ride, but after I shut it down and restart it hoes into limp mode. If I reset the pcm by disconnecting the battery cables and letting the caps drain, it works great the first time out. Then after restarting, limp mode. It works great every time I reset. The last couple times one the second start, the starter only momentarily engages 2-3 times before fully engaging and starting. That goes away with reset too. Im at a loss here. Do you tbink i need te reflash the pcm at the dealer?
thanks for any help and advice.
Old Jan 2, 2018 | 05:17 AM
Vonhofinvule's Avatar
Have you pulled any codes?
Old Jan 2, 2018 | 07:20 AM
Nd48463's Avatar
Default No codes
It's not throwing any codes.
Old Jan 2, 2018 | 02:33 PM
That's strange I though the moment it went into limp mode you'd have seen a code or 2.
Old Oct 9, 2019 | 12:23 PM
jeffcope65's Avatar
Try Vertical Visions, they helped me with my 2011 T & C that had starting problems. They have a patented fuel sensor relay bypass part that is $59.
http://www.verticalvisions.com/
Caliber16
Jul 20, 2019 11:11 PM
Arclark2
May 2, 2018 01:45 PM
Nd48463
9
Jan 20, 2018 11:15 AM
amen.ak
Jul 24, 2016 01:44 PM
sws4420
Apr 19, 2009 10:06 PM
