2010 t&c, ticking noise coming from engine???
Old Apr 15, 2015 | 05:44 PM
krob's Avatar
Default 2010 t&c, ticking noise coming from engine???
I have a 2010 t&c there is a ticking noise coming from the engine. It is constant and starting to get worse. The van only has 72K miles, and has had regular oil changes and maintance done. We took it to a local shop for an oil change and to check on the ticking noise. We were told that it is most likely the rocker arm, and that it is still under warranty because it doesn't have 100K on it yet. Has anyone else had this problem, and is it truly covered by the warranty????
Old Apr 17, 2015 | 03:26 PM
I recon you have the answer so find out what your Warranty covers. Most cover engines so there's no sma writing op outs.
Old Apr 27, 2015 | 02:34 PM
ChryslerCares's Avatar
Hi krob,
For your 2010 model, the powertrain limited warranty lasts for up to 5 years or 100,000 miles on the odometer, whichever occurs first. The powertrain limited warranty covers the cost of all parts and labor needed to repair a manufacturer defect on a covered powertrain component – engine, transmission and drive system – on most Chrysler vehicles.
You can view more detailed warranty information at our website Warranty - Roadside Assistance & Service - Chrysler
andyeastsussex
19
Jun 4, 2015 01:49 PM
jesusayalajr2007
May 13, 2014 05:24 PM
mparsons1
Mar 29, 2012 06:58 PM
Flossie
May 23, 2011 09:42 PM
steviemac74
Feb 28, 2011 06:33 AM
