2010 turn signal replacement
Anyone had to replace the turn signals on a 2010 Towna nd Country? Any ideas on if it is just one bulb to replace or are there different bulbs for the tail and hadlight? Any ideas would be helpful. Thanks
that's better
3. Remove the two retaining screws (2).
4. Insert a trim stick or equivalent to gently pry the lamp unit away from the body and rotate the lamp (1) away from the vehicle body to disengage pin from the grommet in the quarter panel opening.
5. Disconnect the two wiring harness connectors from tail lamp assembly (3).
swittie
Nov 10, 2020 02:02 PM
GSKI
13
Sep 11, 2007 09:33 AM
