2013 Chrysler T&C drivers heated seat not working
So abit strange (because I don't understand). The drivers side seat heater only works if you're not sitting in it! If you're sitting - the lite will stay on then turn off after 2 sec's (no heat). If you're not sitting in it - the lite will stay on and the seat heats up with not problem. As soon as you sit in it - the lite goes out...
All the other seats working fine.
Is there some sensor that's malfunctioning to cause it to shut off the heater once you apply weight (sit down)
Any thoughts would be welcome.
Jan
Jan
Check the wiring harness which comes from the HSM module under the driver seat. You must look for the connector C2. Pin 1 TN/YL is the temp sensor, Pin 3 TN/WT ground and Pin 4 LG/BR is the left front heater pad (cushion and recliner). The 3 wirings goes to a gray connector between cushion and recliner which connects HSM and pad of recliner with the cushion pad + temp sensor. Check for a broken wire.
Jan
Jan
If you decide to visit your local dealership for further diagnosis I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know!
Andrea
Chrysler Social Care Specialist
Anyone find a resolution for this? My 2013 T&C drivers seat isn't heating..... the light comes on for a few seconds (sometimes a little longer) but then shuts off. So frustrated, going to get cold sooner then later. help!!
Good Luck!
I am having the same issues when that you click the button it turns right off again. When remote start turns on the heated seat works completely fine once you start the car it clicks off.
We are looking for any suggestions. It sounds like a relay
I'm sorry to hear of the trouble you are experiencing with your Town & Country! If you're not able to determine a solution based on suggestions provided here and you decide to address this with your dealer, please let us know. We would be more than happy to provide you with an additional layer of assistance for that process.
Mark
ChryslerCares
