2013 Chrysler T&C drivers heated seat not working
Old Feb 7, 2017 | 06:42 PM
Jan Bailey Campbell's Avatar
Default 2013 Chrysler T&C drivers heated seat not working
So abit strange (because I don't understand). The drivers side seat heater only works if you're not sitting in it! If you're sitting - the lite will stay on then turn off after 2 sec's (no heat). If you're not sitting in it - the lite will stay on and the seat heats up with not problem. As soon as you sit in it - the lite goes out...
All the other seats working fine.
Is there some sensor that's malfunctioning to cause it to shut off the heater once you apply weight (sit down)
Any thoughts would be welcome.
Jan
Old Feb 8, 2017 | 01:48 PM
s.m.'s Avatar
Check the wiring harness which comes from the HSM module under the driver seat. You must look for the connector C2. Pin 1 TN/YL is the temp sensor, Pin 3 TN/WT ground and Pin 4 LG/BR is the left front heater pad (cushion and recliner). The 3 wirings goes to a gray connector between cushion and recliner which connects HSM and pad of recliner with the cushion pad + temp sensor. Check for a broken wire.
Old Feb 8, 2017 | 02:35 PM
ChryslerCares's Avatar
Jan
Hi Jan,
If you decide to visit your local dealership for further diagnosis I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know!
Andrea
Chrysler Social Care Specialist
Old Nov 25, 2017 | 05:23 PM
didom76's Avatar
Hello Jan, I recently have the same issue in my 2012 T&C. Did you ever get it fixed? If so, what was the issue causing this to happen? Thanks.
Old Oct 4, 2019 | 10:46 AM
cking's Avatar
Default same here
Anyone find a resolution for this? My 2013 T&C drivers seat isn't heating..... the light comes on for a few seconds (sometimes a little longer) but then shuts off. So frustrated, going to get cold sooner then later. help!!
Old Oct 4, 2019 | 12:14 PM
REBEL59's Avatar
Refer to post#2 by member s.m.. He says what and where to check. And IMO is usually either the electric heat pad under the leather or wire connections to the seat being poor from long term extreme movement to adjust to different drivers.
Good Luck!
Old Oct 17, 2019 | 02:31 PM
Heather Allen's Avatar
Default Did you get your seat fixed?
I am having the same issues when that you click the button it turns right off again. When remote start turns on the heated seat works completely fine once you start the car it clicks off.
We are looking for any suggestions. It sounds like a relay
Old Oct 18, 2019 | 12:16 PM
Hi Heather,
I'm sorry to hear of the trouble you are experiencing with your Town & Country! If you're not able to determine a solution based on suggestions provided here and you decide to address this with your dealer, please let us know. We would be more than happy to provide you with an additional layer of assistance for that process.
Mark
ChryslerCares
BURPLE
Apr 4, 2018 12:03 PM
TomC
Dec 27, 2017 07:43 AM
jlualu1996
Dec 22, 2010 08:05 PM
flaxi
Dec 1, 2007 03:18 PM
Scruffy
Jan 31, 2007 11:18 AM
