51 plate voyager problems
Old Apr 15, 2012 | 06:30 PM
rob&kay's Avatar
Default 51 plate voyager problems
hi just bought a 51 plate voyager 2.5 crd manual
got a few little problems with it
first one is when the lights are on there is no light on the dashboard same as full beam no light on dash bit weird that both bulbs blown if so is it easy to get the clocks out
second problem is the key fob we only got one with im getting no signal from it so im guessing its u/s question is can i get another one from ebay say and programme it to mine if so how i did read somewhere about earthing out a wire somewhere but cant find it now.we can open the car with the key and all doors open and car starts just be nice to have a fob to
third is i can open the boot with the key but the button under the handle where the number lights are doesnt work is that because we dont have a key fob that works
many thanks in advance
Old Apr 15, 2012 | 07:12 PM
rob&kay's Avatar
sorry i put 51 plate i mean it is a late 2001 model
Old Apr 16, 2012 | 04:05 PM
voyager_dan's Avatar
hi , not sure about the clock issue could be bulbs or maybe a fuse
the remote fob you can get another but will have to be programmed by chrysler
the reason for the boot button not working could be a broken wire check in the rubber boots at the top of tailgate also check for a supply at the switch
hth
dan
Old May 2, 2012 | 03:21 PM
scousedave10's Avatar
sound daft but you tried the wheel on right side car it turns off the light on your dials and overhead display it the one that controls the light in the car
Old May 5, 2012 | 08:12 AM
rob&kay's Avatar
i tried that dave first off as used to have a voyager before i sorted out the high beam light just dont seem to have any light indication that they are on
K3nshi
9
Jan 1, 2014 01:34 PM
essjay19762013
May 15, 2013 01:11 PM
dave jackson
Apr 18, 2011 01:37 PM
daddy day care
Feb 25, 2011 12:25 PM
Racinfan83
Dec 10, 2005 11:50 PM
