98 T&C stuck brakes
My T&C brakes locked up and started smoking. Replaced rotors and pads. Tested and everything looked good. After 15 miles , brakes got hard again. Brake pedals were hard. Brakes smoked again.
Now, I'm stuck trying to figure out what the issue might be. Any help is greatly appreciated.
It's not something silly like the pedal won't return to the top for some reason, seized top pivot on the pedal arm for example?
I've had reports of poor brakes or loss of power when the fault has been the floor mats bunched up under the pedals!
Other than that and as CHRYSLER TECH says its not the ABS then I'd recon its the master cylinder. as i said i'm no expert on hydralic brakes but from what i remember if the servo [booster] fails it just gives you no assistance.
Carol_in_FL
Sep 9, 2013 03:57 AM
pete3000
Jul 19, 2011 08:38 AM
goblue2010
Jun 29, 2010 02:05 PM
