99 T&C Accessory Outlet Question
Old Jun 16, 2007 | 08:39 AM
eyruegas's Avatar
Default 99 T&C Accessory Outlet Question
I have two 20A accessory outlets in my 'new' (new to me, of course) 1999 T&C LX. They both appear to be tied to the ignition switch as they do not retain power after the keys are removed.
Is there any (easy) way to convert one or both of these to remain powered after ignition is off? Or am I better off running a new line direct from the battery and installing my own outlet (fused, of course)?
One of my previous cars had a fuse block that allowed me to select whether or not to retain accessory power after ignition-off (might have been my 01 Intrepid?) by moving a fuse from one spot to an ajoining one (it was a 3-hole fuse socket, I believe).
Thanks! (Love this van!)
-Eric
Old Jun 16, 2007 | 09:23 AM
Default RE: 99 T&C Accessory Outlet Question
pretty much no atleast not with out jumping the connections in the ACC relay to make it and everything else that is on that ckt to stay on.
Old Jun 20, 2007 | 07:43 PM
eyruegas's Avatar
I figured as much.
Any tips on running power lines through the firewall? This is my first minivan - difficult to determine if there are any unused plugs in the wall into the passenger compartment... looks like the easiest would be next to the hood release cable... I welcome suggestions! :-)
Hollieking1
Jan 5, 2014 04:55 PM
luckycook82
Feb 6, 2011 11:55 AM
donnyohs
Apr 28, 2009 04:19 PM
Iowacat
Aug 24, 2008 09:44 PM
jquinones
Feb 2, 2008 11:29 AM
