ac not blowing
Old May 15, 2008 | 01:59 PM
Merlin's Avatar
Default RE: ac not blowing
Hi Has to be volt meter time. See if you have power at the fuse? (fuse 10 40amp) if not try swapping the blower motor relay with on of the other. Are we talking variable fan speed control or manual 5 speeds?
Old May 15, 2008 | 09:46 PM
dhhbomb's Avatar
well havent used the volt meter but i have switched all the fuses and relays in the fuse box but its a digital controler so i guess that would be variable fan speed
Old May 16, 2008 | 02:10 PM
Merlin's Avatar
HiWhat about an LED test light? This would make it even easier. The 3 wire plug on the module you changed Pin A is BK/OR wire is the Earth wire. Pin C DB wire is your feed from the relay/fuse. Pin B DB/LB wire is your speed control. Check for power and earth on A and C first. If ok on pin B if you have an LED tester and you probe the wire with it plugged in it will flash at different speeds as you turn the fan switch. All very easy to test.
Old May 20, 2008 | 03:25 PM
dhhbomb's Avatar
thanks for your help beacuse of this test determined that it is the blower motor now just need to replace that if your know how could u please post a simple how to
teddysmith1952
Jul 1, 2013 03:24 PM
pmad
Sep 25, 2011 12:32 PM
AussieAspen
Sep 7, 2011 08:37 AM
BARCLAY
May 19, 2010 04:57 PM
bjbrunk
Feb 5, 2009 08:35 AM
