Add auto-headlight control?
Ohio now requires headlights turned on when wipers are in use. On a '05 T&C can I make the lights come on when the engine is started? I don't have factory automatic HL control. A dealer added or aftermarket kit would be fine. I know I'm going to get a $100 ticket eventually.
Several options. cheapest and easiest way is to train yourself not to be so lazy or forgetful. I'll bet the first couple times you get pulled over, they'll just give you a warning... Ever get caught speeding? did you learn to slow down so you don't get a speeding ticket?
2. See about doing DRL's
3. just turn your lights on and leave them on at all times, even when you shut off the key, the lights will automatically shut off after about 5min. (it's the idiot proof system for people that forget)
4. wire the headlights into the wiper circuit so when ever the wipers are on, so are the head lights. (if you do this wrong, in delay mode, your lights will turn off when the wipers are parked and on when they sweep.... that would be funny since technically the lights come on when the wipers cycle on)
You really can't count on the automatic headlights found in high end vehicles like a T&C LXi/Limited... if it's not dark enough, they don't turn on anyway.
sjones
Mar 3, 2009 09:25 AM
