anyone to advise asap please
Old Oct 18, 2014 | 08:33 AM
  #31
snowprincess's Avatar
[URL="https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/voyager-clutch-problem-6398/
hi i dont know if i have done this correctly but the white flexible arms as shown in the pic from the member are snapped, we have taken it off our car now and sadly the mechanic has not replaced the part as the one we got was from the scrap and was marked incase of return and the one we have taken off is not marked
Old Oct 18, 2014 | 09:04 AM
  #32
Well I have looked at the two photo's and I have to say that is the strangest thing I have ever seen and the method of bleeding described by glowplug is the strangest thing I have ever heard.
From what I can figure out, the plastic clip is only needed if you remove the slave cylinder from the gearbox to prevent the piston from being pushed out of the cylinder (I think) Are you able to see a bleed nipple on the end of the slave cylinder, if so this is used in the conventional way of bleeding a hydraulic line.
Old Oct 18, 2014 | 09:10 AM
  #33
Here is a simple explanation on how to bleed a clutch: Bleeding the clutch | How a Car Works
and here is a YouTube tutorial on bleeding a clutch using the same method that I think glowplug mentioned:
Old Oct 18, 2014 | 09:21 AM
  #34
O.K. I have just watched the YouTube tutorial myself and I have to admit that I learnt something from it. I've not had to bleed too many clutches in my time and never had to resort to the method described in the tutorial but now that I've watched it I understand glowplugs theory and also realise that the plastic clips can be substituted by the 'G' clamp used in the tutorial. You will need to remove the slave cyclinder from the gearbox to use the 'G' clamp method. Good Luck.
Edit: Forgot to mention the the bleed screw is probably protected by a rubber cap to keep the dirt out. This will easily pull off.
Old Oct 18, 2014 | 12:14 PM
  #35
well no joy im afraid the piston on the slave does not move in at all, but the mechanic has definitely not replaced the piece at all as i said it was marked by the scrap place and the one we have taken off had no markings on at all and was a pain to get nuts off as they were seized, now the mechanics not returning our part that we have bought and hubbys kicking himself as he said if he knew in the first place it was that easy to remove and replace he would of had a go in first place
mpls_apple
Mar 22, 2013 09:09 AM
Necro1015
Feb 28, 2013 04:11 PM
dawnp826
Jan 12, 2009 09:48 PM
TricksX
Mar 15, 2007 12:54 AM
Midknight75
Feb 3, 2007 03:34 PM
