Automatic Transmission Leak 2004 GV
Old Apr 27, 2015 | 05:04 AM
travelmad's Avatar
Default Automatic Transmission Leak 2004 GV
Currently hit a dead end. Maybe someone can help.
My GV (auto) has been leaking transmission oil for a while.
First off I changed the oil, sump gasket and filter and afterthat I could see that the solenoid pack was leaking.
Also one of the drive shaft seals looked like it could beleaking. So changed them both, reasonably priced from the US.
Needless to say there is still a leak somewhere, dripsbetween the block and gearbox (when in gear). So im thinking maybe the torqueconvertor or shaft seal into the box. But that will require taking the gearbox out….
The strange thing is that transmission oil is collecting ontop of the box (at the rear) in the cast webbing. First off I thought that itmaybe have got there when filling, but I cleaned it all out and it has sincereappeared. I have also checked the power steering level and it hasn’t moved(since it also uses ATF+4).
Does anyway have an idea how the oil could be getting ontop?
Old Apr 27, 2015 | 01:06 PM
silentdub's Avatar
The axle seals are very cheap and I replaced mine with the axles, they weren't leaking but I replaced them anyway.
My 06 has the pan and a side cover, when you remove them, replace the gaskets with quality rubber gaskets and not the **** the stores try and sell you. Don't over tighten the bolts either.
I've only ever seen the fluid up top from a leaking P/S system.
Old May 25, 2015 | 08:10 PM
pra4200's Avatar
I have a 2006 town & country and the drive axle seals are leaking. could you tell me how difficult it is to change there seals?
Old Jun 8, 2015 | 10:06 AM
travelmad's Avatar
Topping up the box with fluid everyday wasn't an option. So I had the gearbox removed (garage suspected oil pump seal), turned out to be a little more serious!
There is a hole from the diff housing into the bell housing. So the oil was free to flow out of the diff onto the torque converter. Then whilst spinning, the torque convertor would flick the oil up to the top on the box, plus oil out of the bottom.
The is damage to the diff, which must of chipped and made the hole. But no sign of the metal anywhere. So second gearbox was found.
So my GV is back on the road :-) , but my wallet considerably lighter :-(
Attached Thumbnails Automatic Transmission Leak 2004 GV-photo-1.jpg   Automatic Transmission Leak 2004 GV-photo-2.jpg   Automatic Transmission Leak 2004 GV-photo-3.jpg
Old Jun 9, 2015 | 02:05 AM
tfb's Avatar
tfb
Bugger!, glad you found the root cause though
Regards
Richard
zaman65
Apr 25, 2013 06:47 AM
farmerbob02
Apr 13, 2011 12:04 AM
welljr13
Dec 27, 2010 10:26 AM
fyrepower
Nov 16, 2007 07:44 AM
r.tieleman
Mar 23, 2007 09:04 PM
