Bad A/C
Old Dec 23, 2014 | 11:04 PM
Hodges710's Avatar
Default Bad A/C
Does anone know if you cann just detach the compressor and use a shorter belt? Thisis on a 2007 Chrysler Town and Country.
Old Dec 24, 2014 | 02:35 AM
tfb's Avatar
tfb
looking at the belt routing you could probably get away with it, just bypass the compressor and idler pulley. The standard belt is 1.420m, so I would guess you'll need something about a meter.
Has the compressor/clutch seized then?
Regards
Richard
Attached Thumbnails Bad A/C-belt.jpg
Old Dec 24, 2014 | 03:18 AM
royal100805's Avatar
If it's just leaking but not seized and you don't want to repair it just remove the AC clutch relay. This will save having to find and route another belt.
Old Dec 24, 2014 | 04:42 AM
Hodges710's Avatar
Its making a terrible sound, fearing it will seize soon. A/C doesnt work, hasn't for about a year now, rear evaporator and lines are bad. I see rockauto has a bypass pulley setup but I'm fearing through the 3 days that I may be in trouble.
Old Dec 24, 2014 | 04:47 AM
Hodges710's Avatar
Regards
Richard
Thanks Richard but that display doesnt match up to my 3.8, on this display it looks like there are 2 idler pulleys, I have one one.
Old Dec 24, 2014 | 05:33 AM
Does it only squeak with the AC is turned on? If so try turning it off and try again. If it squeaks when the AC Is off then I would imagine you have a faulty compressor clutch. As well as a seized compressor.
Old Dec 24, 2014 | 06:52 AM
Hodges710's Avatar
Its making the noise all the time, I'm just worried of it completely seizing before my parts comes in.
Old Dec 24, 2014 | 11:20 AM
georgef's Avatar
The following applies for the 3.3L and 3.8L engines:
Yes, it can be bypassed using a 79.0" pitch length belt, some people say the clearance between the back of the belt and AC compressor pulley is close, while others say there is plenty of clearance.
Belts that should work:
Duralast 790K6
Gates K060790
Dayco 5060790
Napa 25060790
Goodyear 4060790
Here's a diagram of the bypass belt routing:
If you want to permanently eleminate the AC compressor, Dorman sells an AC bypass pulley (Part # 34241).
George
Last edited by georgef; Dec 25, 2014 at 04:52 PM. Reason: Added this applies to 3.3L and 3.8L engines.
Old Dec 24, 2014 | 01:25 PM
Got a belt description here from someone that removed their compressor and the belt that they found that fitted was 6PK 1285 at 1285mm long.
Old Dec 24, 2014 | 04:34 PM
tfb's Avatar
tfb
sorry, made the assumption is was a 2.8, but you should still be able to do it.
Regards
Richard
