Bad A/C
Old Dec 27, 2014 | 01:19 PM
rodger's Avatar
This is for bypassing a 2.8 CRD so the dimensions wont help you, but get a straight edge rule to try and determine if the belt will miss all the obstacles. As for the length I had to have 3 guesses it was alway shorter than I thought, hope this helps.
Rodger
Old Apr 15, 2015 | 03:02 AM
Munro's Avatar
Default Seized compressor bypass serpentine belt petrol
My aircon compressor seized this week whilst my Wife was driving...panicky phone call saying smoke was pouring out from the bonnet/hood and will not run. I feared the worst.
By the time I got there the smoke was gone, but not the ghastly smell. Engine would barely crank and failed to start, so used jump leads to see if I could duplicate the problem (fire extinguisher in hand). Cranked slow and then engine fired up with an awful screech....belt noise. Cut the belt and crept 2 miles home with no water pump, no alternator, and worst of all no power steering. By hand it felt like the AC pulley was seized. I needed the van quickly for my Daughter's 16th birthday, so a quick fix required. THE CHRYSLER FORUM TO THE RESCUE!
A big thanks to GEORGEF who makes an excellent post above. Using his accurate and complete advice I got a smaller serpentine belt (US 79" equals EU 2005 mm so Gates K060790 = Gates PK062005) and bypassed the aircon pulley. On my petrol 3.3 2005 the back of the belt just touched the aircon pulley - ran fine with no noise or heat, but I then decided to remove the aircon compressor just in case, as I shall have to replace that eventually. Back on the road.
PS: the tensioner on this vehicle has a 1/2" female square drive in just the wrong place, so instead used the 3/4" square male dog on the bottom with a 12" adjustable wrench...by chance a 12" adjustable will rotate the tensioner and can be wedged against the aircon pulley leaving you one hand free to fit the belt - thanks also to this forum for suggesting the 3/4" dog on the bottom.
A BIG THANK YOU goes out to all those who post responses on this site...keep up the good work. I'll be looking for a used aircon compressor soon.
Happy Motoring.
Old Apr 23, 2015 | 10:47 AM
silentdub's Avatar
I don't know how anyone does without A/C. Those compressors will make noise for a long time before locking up.
Old Apr 23, 2015 | 11:27 AM
John Norrish's Avatar
E Bay USA have a look you will find a support and new Pulley to replace the air con so you can use the same belt only about 25 Dollars
Old Apr 23, 2015 | 03:12 PM
  #15
So we have bypass A/C Compressor belts on this thread for petrol and diesel engines. No doubt this will come up yet again and will be of help to someone.
Old Oct 29, 2015 | 01:08 PM
  #16
Mobile66access's Avatar
Default Shorter Belt for bypassing the AC pump - grand Voyager 2.8 CRD - 2004
Originally Posted by tfb
sorry, made the assumption is was a 2.8, but you should still be able to do it.
Regards
Richard
Hi Richard, I know it was a while ago but can you remember the length of Belt I will need to bypass the AC compressor on my Grand Voyager 2.8 CRD - 2004 vintage?
Thanks for any help, Graham
Old Feb 18, 2023 | 08:31 AM
  #17
DMarie87's Avatar
Originally Posted by georgef
The following applies for the 3.3L and 3.8L engines:
Yes, it can be bypassed using a 79.0" pitch length belt, some people say the clearance between the back of the belt and AC compressor pulley is close, while others say there is plenty of clearance.
Belts that should work:
Duralast 790K6
Gates K060790
Dayco 5060790
Napa 25060790
Goodyear 4060790
Here's a diagram of the bypass belt routing:
If you want to permanently eleminate the AC compressor, Dorman sells an AC bypass pulley (Part # 34241).
George
2006 Chrysler town and country 3.8L. The 790K6 belt worked excellent. Took the bad ac compressor out cuz it was too close for comfort.
jtminnc
Oct 31, 2010 07:08 PM
ramfan5.9
Jun 26, 2007 07:07 PM
Racinfan83
Jun 26, 2007 07:03 PM
Nov 2, 2005 12:37 AM
May 1, 2005 06:20 PM
