Battery light on dash is ON
Old Jun 19, 2020 | 09:10 AM
mixnight's Avatar
Default Battery light on dash is ON
Good morning, randomly the battery light on the dash is on for some reason, one day is on, next days is off, I went to Advance Auto Zone and the scanner read the battery, alternator and starter and they are OK, no malfunctions, I need to mention that the head lights and fog lights are in auto mode and when they are on, the two icon lights on the dash are ON, what I noticed couple of days a go is that the the fog lights and it's icon light on the dash were OFF and the battery light on the dash was ON, I thought that one of my kids were pushing buttons so I tried to turn it back ON but it just didn't work, so I started to pay more attention to this issue: when the battery light on the dash is ON, the fog lights won't work even if they are turned ON and it's icon light on dash is OFF, I replace the M2 corresponding to the fog lights but it is still not working when the battery icon light on the dash is ON.
Is there any other cause to this problem, or any solutions to this?
Thank you,
Old Jun 19, 2020 | 09:15 AM
mixnight's Avatar
I forgot to mention: this is a 2012 town and country.
Old Jun 20, 2020 | 08:57 PM
likely an alternator issue need to have a volt meter looking at battery voltage when the light is on having then scan it when the light is off will do no good.
Old Jun 23, 2020 | 08:04 AM
mixnight's Avatar
I went to Advance auto zone for a second time when the light was ON, they tested the battery, alternator and starter and everything is good, no problems found. The light is still coming On and OFF randomly.
Old Jun 24, 2020 | 08:53 PM
You did not listen to what I said. YOU NEED A VOLT METER PUT ON THE BATTERY WHEN THE BATTERY LIGHT IS COMING ON TO SEE WHAT THE VOLTAGE IS. Did not say anything about going to advance auto to have them put there POS non conclusive tool on the car.
Old Aug 13, 2022 | 02:14 AM
townandcountry_los's Avatar
Default Battery light on.
I have the same issue. The battery tests fine. The voltage while the car is running is over 13.6 volts. I had firestone look at it and they said the battery was bad. It was under warranty but checked out fine from Autozone but they replaced it anyway. Firestone checked again and they couldn't find anything wrong with the alternator. They replaced one of the cables (positive the negative had already been replaced). The light when off for awhile and then came back on.
Old Aug 14, 2022 | 06:15 PM
If the issue is not present when some one tests it there will be no conclusive why to determine the issue. DO you go to the DR when your not sick?
Old Aug 15, 2022 | 01:02 PM
woodthumb's Avatar
change the battery....95% of all these little elec snafus are caused by that... crazy what a weak batt will do ....report back.. i was wrong...once
Old Aug 20, 2022 | 08:37 AM
gorilla's Avatar
could be the serpentine belt + or the belt tensionor - bearing thingy is old + causing a belt slipping mode under a big load ???
them ecm computers are really stupid sometimes in there thinky modes
Balfa1983
Apr 18, 2012 05:05 PM
GreyGoose
Nov 22, 2009 02:58 AM
KYBarrister
Oct 22, 2009 10:04 PM
indysebring
Oct 22, 2009 03:05 AM
ietk
May 3, 2008 05:12 PM
