Boost Sensor 2003 2.5CRD Test.
Old May 13, 2015 | 03:37 PM
Default Boost Sensor 2003 2.5CRD Test.
Going to run test wires from Boost sensor to Dash mounted volt meter to check output voltage through idle which should be about 1.9v to foot down, overtaking mode. There's 4 wires to sensor, anyone got wiring diagram as to wires to test on.
Old May 13, 2015 | 04:03 PM
tfb usually has the spark chasing diagrams goggsy, no doubt hell spot this post and help when he has time [he works night's mate].
Old May 14, 2015 | 10:57 AM
tfb's Avatar
tfb
it's a pressure and temp sensor
1 DB GND
2 DB/LG Temp sensor signal
3 LB/PK +5V reference voltage
4 DB/YL Boost signal
Regards
Richard
Old May 14, 2015 | 03:13 PM
Good just got to add offtake connectors to these wires. I used to use bullet connectors the old soldiered type, I now use Crimp bullets, male and female. Not very elegant some would say seeing these atop engine. Anyone got ideas for connectors to the 4 wires. Could trace them back but all wrapped in tape.
Old May 14, 2015 | 05:49 PM
Some use glue shrink I use cheap heat shrink cut to size - after - first soldering the wires together properly old school, the joint never comes apart and never ever suffers from condensate[s]. A more expensive version is soldered shrink. Best of luck goggs !
Bee
Nov 29, 2014 02:30 PM
Randy L
Sep 23, 2014 12:45 PM
VVVVVVVVVVVVVVm
May 25, 2013 12:10 PM
kobbie
Oct 9, 2008 10:10 AM
austin1357
Apr 12, 2008 01:21 PM
