Boot wont open without key
I believe there is some tie up between the built in alarm system and the boot lock mechanism. My first Voyager had this problem and also the alarm LED was/is on solid. As these systems are well known for packing up I suspected that someone had done something in the boot to effectively disarm the system. As such I have just left it like that. I have subsequently bought another Grand Voyager and all its doors function correctly.
Chrysler charge a lot to sort out alarm systems on these cars so my advice to you is just put up with it. You can lock and unlock all doors from the boot. If you turn the boot lock to the right and hold it firmly in that position all other doors will unlock. Turning to the left will lock all doors.
When I looked for a replacement switch, it was going to be silly money (about £70 for a second hand switch and there was no guarantee that it would be any better than mine). The solution I used was to get a heavy duty stainless steel button switch from Maplins (about £5) and drill a hole next to the existing switch to fit this. You will need to wire the 2200 ohm resistor in series in the wiring. Mine works perfectly now.
hi there
(if someone still looking for this post as it os quite old one)
I just found this post where I was looking for solution for a while,
mine is exactly the same.
Could you tell me what watt resisor did you use if you remember as there is a huge range of choice on the market (I looked ebay and there is 1W - 100W)
chrysler5569
Jan 6, 2015 07:45 AM
itschuckster
Oct 8, 2011 04:16 PM
t_bone_u13
Oct 29, 2007 10:20 PM
andrew86
Dec 8, 2006 07:25 PM
