A brain teaser...
Old May 13, 2014 | 06:41 AM
Leedsman's Avatar
Default A brain teaser...
You have a battery which measures 12.8volt off-load. When you place a 1amp. load on it (a 12watt lamp) the terminal voltage drops to 12.7volt.
What is the internal resistance of the battery? Two sig. figs. will do.
Where would you find such a battery?
Leedsman.
Old May 13, 2014 | 10:57 AM
tfb's Avatar
tfb
If you want an accurate answer then measure the resistance of the bulb, the figure of 12W is a nominal figure and any resistance you calculate from it could be off by quite a bit.
As for finding a battery by a specified internal resistance, I know Yuasa give it on their data sheets but never noticed it on car batteries
Regards
richard
Old May 13, 2014 | 04:03 PM
Leedsman's Avatar
Upon trying this with a real 12volt lamp, the measured current flowing was exactly 1amp. (The hot resistance will consume 12watt. The filament resistance is much lower when cold of course).
Try again. The data provided will indicate the internal resistance of the battery, be assured.
Leedsman.
Old May 15, 2014 | 10:55 AM
tfb's Avatar
tfb
0.098 ohms
Regards
Richard
Old May 16, 2014 | 09:46 AM
Leedsman's Avatar
Correct answer Tfb, and the place you're likely to find one like this is on....
A motorbike.
Leedsman.
Fhorlando
Dec 22, 2014 01:10 PM
