Brakes on 2004 3.3 G/V (T&C)
Old Mar 18, 2017 | 07:33 AM
John Jarman's Avatar
Default Brakes on 2004 3.3 G/V (T&C)
Hi,
What is involved in removing the ABS control block from above the Xmember? Is it as impossible as it looks?(!!)
JJ.
Old Mar 20, 2017 | 03:21 PM
The last time someone renewed this block on here it turned out to be a simple wheel sensor after all the work.... So what's your problem.
Old Mar 21, 2017 | 03:44 AM
Thanks for replying.
The problem is solved - partially at least. I had fitted new brakes all round (pads, callipers and rotors) but couldn't bleed the rt rear/lt front. The brakes had been ok before but a slight shudder from the rear on heavy braking. I eventually found a split in that circuit's pipe - m/cyl to abs block. It looked impossible to remove the pipe from that block, hence the post.
I've now cut a hole in the floor to access that pipe union which, sods law, was the least accessible on the block. Just got to make up and fit a new, slightly re-routed pipe.
It seems the pipe split while bleeding the good circuit as no leak before but pipe had rubbed thin against wiring conduit. I only got to find the split by taking out the wheel-arch liner.
JJ.
Old Apr 1, 2017 | 04:27 AM
As a follow-up, in the end I had to order a new pipe. Being in the UK, it had to be ordered through a FIAT dealer and sent from Italy. I decided to get both pipes that run from the master cyl. to ABS module, to be on the safe side while I had the hole in the floor!!
They were awkward to get in but everything now ok.
JJ.
thundergod66
Jan 16, 2013 10:56 PM
flyfishmi10
Aug 24, 2012 03:42 PM
Monro400
Oct 14, 2011 06:39 PM
viffer06
Jul 25, 2010 03:35 AM
mom2twinsplus1
May 23, 2010 03:05 AM
