Changing turn lamp
Old Mar 22, 2015 | 01:58 PM
harrym's Avatar
Default Changing turn lamp
My left rear turn light is burned out. How do I get into the lamp housing to change it? I don't see any screws holding the cover on.
Old Mar 22, 2015 | 03:04 PM
You'll need to give a better indication of what car you have got.
Old Mar 22, 2015 | 04:21 PM
harrym's Avatar
I have a 2010 Town and Country van.
Old Mar 22, 2015 | 07:27 PM
Vmaxxer's Avatar
I don't know if its the same as my 2002 but in my case its 2 black plastic plugs I need to pull out with a flat screwdriver.
After removing those 2 plugs I can remove the housing.
Old Mar 23, 2015 | 12:16 PM
harrym's Avatar
There are no black plastic plugs on this unit. It looks like it is glued to a wraparound piece of plastic that is secured with two torx screws. I loosened them but the piece won't come off. I don't want to break it by forcing it. Is this the way to remove the cover?
Old Mar 23, 2015 | 12:38 PM
Vmaxxer's Avatar
This is in the 2010 manual, same as 2002 except its 2 screws in stead of 2 plastic plugs
Old Mar 23, 2015 | 06:20 PM
harrym's Avatar
Thanks. It was easy if you know how. It's changed and working.
swittie
Nov 10, 2020 02:02 PM
alparsalan
Feb 22, 2008 10:46 AM
t_bone_u13
Oct 29, 2007 10:20 PM
onedownfiveup
Jan 20, 2006 06:15 PM
onedownfiveup
Jan 17, 2006 04:20 PM
