Charging Problem?
Old Mar 17, 2011 | 06:13 PM
Rangr90's Avatar
Question Charging Problem?
Question if you disconnect the neg. terminal on the battery while the engine is running and the engine stays running does that tell you that the altinator is good?
Rangr90
Old Mar 17, 2011 | 07:03 PM
Djinn-n-Tonic's Avatar
No....
Unfortunately ..that neat little trick hasnt been successfully conclusive since 1962, and also runs the risk of popping a diode in the regulator assembly of your PCM....
A 10 $ "Walmart special" multimeter will do the job, without damaging anything...
2 things are possible with the pull the cable trick.....1) the engine stalls...because you "Ungrounded " the PCM.....or 2...It keeps running, and builds up a dangerous amount of current, with no place to discharge it.....Either way...you have not "Proven" anything, and possibly irreparably hurt it in the process.
Old Mar 17, 2011 | 07:24 PM
Rangr90's Avatar
Djinn-n-Tonic
Thanks for your help.
Rangr90
Johnja
Nov 4, 2007 04:53 PM
mrbradva
Sep 30, 2007 01:03 PM
new2me
Other
Feb 10, 2006 12:03 AM
drwalker88
K-Cars
Jul 8, 2005 02:32 AM
drwalker88
Other
Jul 7, 2005 03:40 AM
