Check engine light and "gas cap" message....help
Old May 9, 2018 | 08:58 AM
sanb0rn's Avatar
Default Check engine light and "gas cap" message....help
In my 06 town and country the check engine light is on and the message gas cap is displayed on the odometer. I have changed the gas cap and it didn't solve the issue. I went to advance auto parts and had them scan it and codes were all about the gas cap. I did the 3 turns of the key and got a p code on the odometer. Can't remember exactly the nbers after the letter P. Any suggestions. I need to get it fixed for e check by next month. Thanks
Old May 9, 2018 | 12:50 PM
REBEL59's Avatar
Probably P0442, Small or medium vacuum leak detected in EVAP system. A common fault I have encountered is a loose plastic evap tube connection to a rubber hose connector UNDERNEATH the air filter housing. NOT hard at all to remove the whole air filter housing to check it out.
calamity coyote
Mar 24, 2019 10:47 AM
mjr46
Feb 11, 2019 07:04 AM
HowieF16
Oct 13, 2014 03:49 PM
Oleg
Feb 16, 2009 10:31 AM
PequenA
Jan 13, 2009 07:12 AM
