Chrysler Grand Voyager 2005 rough idle
Old Jun 16, 2017 | 08:54 AM
qstore4814's Avatar
Default Chrysler Grand Voyager 2005 rough idle
Hello everyone, fairly new here, I have a recently purchased Grand Voyager 2005 model, with a rough idle. (Came with problems) Trying to find the issue. Previous owner has installed new plugs, leads, and coil pack. Had an engine analyser on it and it still points at the coil pack. However I don't think it is an accurate analysis as this is the second coil pack on the vehicle from the original. The previous owner had an analyser on the vehicle and it pointed at Air Flow Sensor. The indication I was given over the phone was that the Air flow sensor was 'unplugged'. Also the Catalytic converter may be damaged as it was making strange noises at idle. Again Idle is rough but no codes in the odometer after the ignition test. I have googled this a bit and it seems to make sense as the Catalytic converter can be damaged due to different temp for fuel ignition? The airflow sensor may be called Airflow Pressure sensor for this vehicle. What do you think?
Old Jun 16, 2017 | 08:56 AM
qstore4814's Avatar
Forgot to add: Check engine light is on.
Old Jul 3, 2017 | 03:58 AM
swiftgate's Avatar
get THROTTLE BODY and EGR cleaned... I assume the mileage might be over 40k or it may be driven in very dusty conditions. If it doesn't resolve then change CAMSHAFT POSITION SENSOR and CRANKSHAFT POSITION SENSOR
All the best
Old Jul 3, 2017 | 03:51 PM
Yes sticking EGR can give rough uneven running on most petrol engines.
Curtis Wright
Feb 26, 2017 12:50 PM
70 roadrunner
Dec 3, 2014 07:48 AM
arsace13
Feb 5, 2013 09:58 PM
rsv1000
Nov 30, 2010 09:05 AM
