Chrysler Grand Voyager 2005 v6 3.3 wont go past 2500 RPM problem
Old Feb 8, 2012 | 09:29 PM
qwerty's Avatar
Default Chrysler Grand Voyager 2005 v6 3.3 wont go past 2500 RPM problem
Hello,
I have a Grand Voyager 2005 v6 3.3 petrol & i have a problem with it
It was an old problem that went away but has recently returned
The car drives fine, starts fine & changes gears fine (automattic) but when it hits 2500 rpm it wont rev anymore & wont drive it actually jerks back & forth but as soon as i go below 2500 rpm it drives fine, I have changed oil, spark plugs, oil filter, injectors were removed & cleaned & new cam & crank sensor but the problem is still there.
PLEASE HELP
Old Feb 9, 2012 | 01:39 AM
Raptor 07's Avatar
I would suspect a fuel pump that can't keep up with demand. Connect a fuel pressure gauge and see how close it comes to the 55 psi spec.
Old Feb 9, 2012 | 03:49 AM
qwerty's Avatar
thank you i will book the car in with a local mechanic as here in Australia the Chrysler Dearler mechanics are useless, twice they tried to repair it & both times the problem was still there & now they are telling me i need to replace the wiring harness.
Old Feb 9, 2012 | 02:08 PM
Raptor 07's Avatar
Did they change anything the first two times? Which harness? Were you getting a check engine light and did they check for codes?
Old Feb 9, 2012 | 07:19 PM
TNtech's Avatar
In addition, max 2500 RPM can be an issue with cam and crank sensors not being in sync for some reason. A bad cam sensor, crank sensor, timing chain stretched (highly unlikely) or a broken and shifted flexplate. If they can read the PCM data, tell them to look at CAM/CRANK Difference. Also tell us the codes that they pulled...if any. Guessing P0016 and/or P0344/P0340
Don't give them too much grief. I doubt there are very many training centers and/or opportunities to see issues with "foreign" cars. But, under NO circumstances let them replace your wiring harness. That is a shot in the dark that almost always ends badly.
Old Feb 14, 2012 | 10:15 PM
qwerty's Avatar
Regarding the broken and shifted flexplate it actually broke last night so i have to pull gearbox out to replace it so hopefully that this is the problem
Old Feb 15, 2012 | 09:12 AM
TNtech's Avatar
Well, at least you know what it is now. When you get it out you will see the tone ring that the crank sensor reads. If it shifts just a little, it throws off the sync with the camshaft sensor. What happened was that the center separated enough to allow the flexplate to shift a few degrees. Sometimes it takes quite a while for it to completely separate though.
Old Mar 11, 2012 | 03:49 AM
qwerty's Avatar
replaced broken flex plate but the problem still there now it wont even start well it will start after about 30 seconds sometimes longer as it keeps cranking over & when i finally get it started it still will only rev to 2500 RPM
anymore advice please
sangria
Jul 25, 2019 12:11 AM
denn3.0v6
Oct 1, 2012 12:27 PM
tottos6
Jul 10, 2011 09:26 PM
barebones
Oct 16, 2010 01:01 AM
sangria
Oct 4, 2010 10:31 PM
