Climate Control Sticks on 96 Grand Voyager SE
Old Apr 19, 2007 | 12:54 PM
auggievan's Avatar
Default Climate Control Sticks on 96 Grand Voyager SE
My 96 Grand Voyager has had a problem for two years. If I set the temp up high in the AM to assist the defrost then no matter which setting the slider is set to for many hours (sometimes days) the heater puts out hot air. It is currently stuck in the cold setting. The problem is intermittent, it worked perfectly well two days ago on one particular trip adjusting from cold/warm/hot and back again (but it malfunctions more days than it works). I just finished running the recal on the system I saw recommended in a different post and the system passed this test. Recommendations?
auggievan
PS: the information on the recall for the clock spring has made my day, if I get this heater thing fixed I may not be driving a Toyota Van by the end of the summer.
[align=left] [/align]
Old Apr 19, 2007 | 02:03 PM
Default RE: Climate Control Sticks on 96 Grand Voyager SE
NO: 24-16-95 SUBJECT: HVAC Diagnosis DATE: Dec. 8, 1995 SYMPTOM/CONDITION: [ol][*]A/C blows hot air on passenger side/driver side or both.[*]Air blows through defrost or panel outlets only (mode will not change).[*]Fault codes (flashing HVAC indicator lights/LED’s) are intermittent without explanation.[*]HVAC control is locked in the diagnostic mode, cannot abort.[*]HVAC control suddenly goes dead (doesn’t light up or have any effect on HVAC operation), skip to the Secondary Diagnosis section of this bulletin.[*]HVAC control has blinking LED’s which do not correspond to a fault code listed in the service manual.[/ol] NOTE: IF THE DIAGNOSTIC PROCEDURES LISTED IN THE 1996 TOWN & COUNTRY, CARAVAN AND VOYAGER SERVICE MANUAL SUPPLEMENT (PUBLICATION NO. 81-370-6105A, DUE TO ARRIVE AT DEALERSHIPS NO LATER THAN MID-DECEMBER 1995) HAVE BEEN EXHAUSTED WITH NO PROBLEM FOUND, SKIP TO THE SECONDARY DIAGNOSIS SECTION OF THIS BULLETIN. DIAGNOSIS: With the engine running, look at the HVAC control LED’s, if they match any of the combinations below perform the necessary tests as indicated. Rear Wiper and Intermittent Rear Wiper LED’s flashing at the same time, indicates the Calibration/Diagnostics test has failed and a failure code is stored. Run the Calibration/Diagnostics test as described on page 24-7 of the 1996 Town & Country, Caravan and Voyager Service Manual Supplement (Publication No. 81-370-6105A). The failure code will be displayed, refer to page 24-8 for the description of the failure codes/level display and "HVAC Control Diagnostic Conditions" starting on page 24-9 for a description of the diagnostic procedure for the displayed failure code. A/C and Recirculation LED’s flashing at the same time, indicates the Cooldown test has failed. Run the Cooldown test as described on page 24-7. If the Cooldown test fails again perform the diagnostic procedures listed for HVAC Control Diagnostic Conditions "A/C and Recirc LED flashing simultaneously' on page 24-11. Rear Wiper and Intermittent Rear Wiper LED’s flashing at the same time and A/C and Recirculation LED’s flashing at the same time, indicates the Calibration/ Diagnostics test has failed and the Cooldown test has failed. Run the Calibration/ Diagnostics test as indicated on page 24-7. If the A/C and Recirculation LED’s do not stop flashing, run the Cooldown test as described on page 24-7. NOTE: IF THE COOLDOWN TEST IS RUN DURING COLD AMBIENT TEMPERATURES, PASSING THE TEST MAY BE DIFFICULT. FOR THE COOLDOWN TEST TO BE PASSED, THE VEHICLE SHOULD BE BROUGHT INTO A SERVICE AREA THAT IS AT 70 °F. (21 °C.) OR HIGHER AND ALLOWED TIME TO FOR THE VEHICLE INTERIOR TO COME UP TO THE SERVICE AREA TEMPERATURE (RUNNING THE ENGINE WITH THE HEATER ON HIGH BLOWER, AND TEMPERATURE CONTROL SET TO FULL HOT CAN HELP REDUCE THE TIME REQUIRED) BEFORE THE COOLDOWN TEST IS RUN. If no lights are flashing, run the Calibration/Diagnostics test as indicated on page 24-7. If a failure code is displayed, refer to page 24-8 for the description of the failure codes/level display and "HVAC Control Diagnostic Conditions" starting on page 24-9 for a description of the diagnostic procedure for the displayed failure code. If, after performing the appropriate diagnosis listed above, a defect is not found but the HVAC still is not functioning properly, check the HVAC system wiring. It is possible a wire may be shorted to ground or has an intermittent connection. SECONDARY DIAGNOSIS: [ol][*]If the HVAC control symptom is that it suddenly goes/went dead, check for a loose/unseated 21-way connector behind the HVAC control.[*]Inspect the HVAC 14-way connector (accessible by removing the instrument panel top cover). Check each pin (except for pin 2, actuator feedback/sensor return, which is ground) of the 14-way HVAC connector for continuity to ground with an ohmmeter. If a grounded wire is discovered, locate the point at which the wire is grounded and repair the wiring (be sure to check all wires at that point for a possible grounded condition). Inspect the following areas first if a grounded 14-way connector wire is suspected: (See Illustration and See Illustration) [ul][*]HVAC wiring harness 4-5 in. from the 14-way connector on the HVAC unit near the air bag bracket.[*]Wiring routed between the HVAC unit and the dash panel (bulkhead). HVAC unit removal is required to access this location if the wiring was not properly routed on the HVAC unit.[/ul][*]Remove the HVAC control and disconnect it from the 21-way connector. Check each pin (except for pin 21, which in ground) of the 21-way HVAC control connector for continuity to ground with an ohmmeter. If a grounded wire is discovered, locate the point at which the wire is grounded and repair the wiring (be sure to check all wires at that point for a possible grounded condition). Inspect the following area first if a grounded 21-way connector wire is suspected: [ul][*]The 21-way wiring harness where it is routed through the metal frame of the instrument panel behind the HVAC control.[*]Looking from the driver's side floor, large bracket makes the mode door actuator of the HVAC unit difficult to access. Inspect the wiring for being pinched or cut by the bracket (if grounded wiring is discovered at this point, be sure to remove any sharp edges that may be on the bracket and repair the wiring).[/ul][/ol] Verify proper HVAC system operation by running the Calibration/Diagnostics test as described on page 24-7 after all repairs have been made. POLICY: Information Only
Old Apr 19, 2007 | 04:57 PM
auggievan's Avatar
Thank you for your quick response. However, I already ran that calibration test and it passed. Any other recomendations?
auggievan
Old Apr 19, 2007 | 10:01 PM
there are 2 recalls which one did u do the cool down or the cool down plus door recal? if i remember right hold down the 2 lower ac and rear wash that should do the doors plus ac cool down u will know if the door one is doing its busness the air flow will move all around.
Old Apr 22, 2007 | 05:36 PM
auggievan's Avatar
I followed the following procedures which I had pulled from a post before first posting my problem:
COOLDOWN TEST ENTRY TO INITIATE TESTS:
* Set Blower motor ON HIGH
* Set Mode position to Panel
* Open all A/C outlets
Set Temperature to Cold (Both slide pots if equipped)
* Depress WASH and A/C simultaneously for 5 Seconds
NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test. RESULTS:
* All LED's will turn on for 5 Seconds
Cooldown Test is running when A/C and RECIRC. are alternately flashing. If A/C and RECIRC. are flashing simultaneously, Cooldown has failed.
When I called into a Chrysler dealer and read off my VIN, they said I was only due the clock spring recall. Do you have any other details on what recall I should ask for?
Auggievan
PS I will be at the dealer tomorrow for the clock spring, so any information on other recall about the controls for heating cooling would be appreciated.
Old Apr 22, 2007 | 08:23 PM
u dont ask for recalls they show up when the vin is run if u dont have ne then u dont have ne
Old Apr 23, 2007 | 03:48 AM
auggievan's Avatar
Okay, got the recall part. Is there any other diagnostics or suggestions for my irratic heat control. I appreciate your help.
auggievan
Old Apr 23, 2007 | 10:20 AM
not over then net i would haft to see what is going on in person
Old Apr 23, 2007 | 10:26 PM
auggievan's Avatar
thank you
travelmad
Dec 31, 2011 04:03 PM
mikeinoz
Sep 2, 2010 08:34 AM
daswitz
May 7, 2008 02:55 PM
mick_n3
Oct 18, 2007 01:24 PM
daswitz
Apr 15, 2007 10:58 AM
