Clock spring?
Old Jun 25, 2011 | 06:28 AM
bumblebee's Avatar
Default Clock spring?
ok same vechile 3.3 grand voyager uk model
airbag light wont go out but horn and cruise control both work fine is this still going to be the clock spring according to my local dealer there is nothing wrong with the spring as these never fail ,
i did the code thing where u hold the milage reset button down etc and it just goes threw diffrent postions of the needles etc and doesnt show any numbers etc after. and i cant find clock springs online do u think its still the spring if so can i replace this myself
Old Jun 25, 2011 | 07:35 AM
that wont work with an air bag system U will need to have a scanner hooked up to it that will get into an air bag computer
Old Jun 28, 2011 | 08:42 PM
ajs42548's Avatar
Default clock springs do go
Clock springs do go. I had 2 different Chrysler minivans where the clock spring had to be replaced. That said, when the clock spring goes, the horn will not work, so if your horn works then it's probably not the clock spring. And no, you can't replace it yourself as it involves the airbag.
Old Jun 28, 2011 | 08:57 PM
Djinn-n-Tonic's Avatar
Not necessarily true.... It usually ends up that way...but it doesnt have to....
Clockspring handles horn, airbag, cruise control, and on later models it can also handle "Wheel Mounted Radio Controls" or "Driver Option Menus in the EVIC.
Any of these Items could fail due to a faulty clockspring.....But it isnt Mandatory that all of them be inoperative to condemn a C/S.
As for doing it yourself.......Ummmm..... That could go either way....
It isnt that difficult of a Task, and Plenty of Home Brewed mechanics have successfully changed them.
That said, Even the most seasoned professional technician is Not Immune To the BROKEN NOSE when the bag goes off in your face....
"Trust Me...It HURTS..."
Old Jun 29, 2011 | 09:02 AM
ajs42548's Avatar
I stand corrected as far as the horn is concerned. But when I said you can't change the C/S yourself what I meant that yes you can do it but the odds of setting off the air bag it very great and not worth doing it yourself because of the cost in money and injury. Anything can be a do it yourself job but in many situations they really aren't. I mean I can change the struts myself but I would never actually try it because of the danger involved for example.
Torancis_Chrysler
32
Feb 5, 2016 03:49 PM
John Wilson
Oct 21, 2014 09:55 AM
memikee
Oct 2, 2014 07:12 AM
cowli4nia1
May 4, 2010 09:52 PM
mwstant
Jun 16, 2009 03:50 PM
