Clutch change
Old Apr 8, 2009 | 07:36 AM
Seph's Avatar
Default Clutch change
Hi i am doing a clutch change on my voyager 99 plate 2.5td, i am having trouble getting the box apart from the engine. all the bolts are out and the gearbox will lever about 10mm away from the engine, but not were the starter motor is it is still tight. there is 1 starter motor bolt left in at the top which i cant get to but that only goes into the spacer between the box and engine. is there somthing else holding it together i have missed??
Old Apr 9, 2009 | 04:35 AM
glowplug's Avatar
At the back of the engine just below the starter motor you removed a big nut right?? and now you can see a stud sticking out through the engine mount. Well guess what that stud has another side that goes through the crankcase and into the gearbox. I know cause I struggled just like you until I found this ba****d.
Old Apr 26, 2009 | 03:18 PM
Seph's Avatar
thanks mate thats exactly what it was i managed to find it before i checked back on here though.
flaxman
Sep 5, 2011 02:10 AM
Jamie
May 8, 2007 02:47 PM
beatle78
Mar 8, 2007 04:39 AM
morevert
Dec 8, 2006 08:51 PM
Oct 14, 2006 05:48 AM
