Code P 165.1 after a key dance
Old Mar 7, 2016 | 02:43 PM
darkcild101's Avatar
Default Code P 165.1 after a key dance
I have searched online and there is nothing on this code
Old Mar 7, 2016 | 03:11 PM
::::::::::::::::::: IPM and sidelights. Have you had power to lights problems ? Have a look at the 'fuseholders' and underside of the fusebox. Have you / someone bodged a stolen power line from the lights / instruments ? Get tfb / someone to give you a read !
Old Mar 8, 2016 | 02:25 AM
dieselvoyager's Avatar
Root cause could be EGR not working right (now I know your EGR controle pipe is / was broken) !
Old Mar 8, 2016 | 02:42 AM
P Code only tell you about an error not all ways what the real fault is.
P 165 is O2 sensor slow response & this could lead to EGR valve not working right. O2 sensor tell ECU what EGR is suppose to due and with a broken EGR control pipe you get an error in ECU. fix the pipe and reset ECU manny time the read out is an old stored error not valid anymore.
I all ways used DRB III scanner and it tell you if it's a active or stored error.
Old Mar 8, 2016 | 04:05 AM
tfb's Avatar
tfb
There is no 02 sensor on a diesel voyager.
The 1651 error code is a data transmission error between the ECU and instrument cluster
Richard
Old Mar 8, 2016 | 06:37 AM
Richard
Tfb strangely the format is different from normal codes i have seen previously. This one actually has . in the middle. I will type as it is P 165.1
Old Mar 9, 2016 | 04:47 AM
Default O2 sensor on diesel models
Richard
Well I have never seen a Diesel RG model with out O2 sensor ! . How do you Think EGR valve is controled , By mass Flow and O2 sensor RIGHT
Old Mar 9, 2016 | 07:31 AM
O2 sensors can last up to 100k, what many don't realise is that as they get older they still work, but work less efficiently and the reporting range of 1 to .9v in .5v increments become slower and slower and less and less accurate with the obvious fuel issues.
Mopar Oxygen Sensor 56028995AA
The difference between the RS/RG/RT VM Motori & the RS/RG Chrysler builds are here.
Old Mar 9, 2016 | 08:35 AM
I am confused whats this RG model? Where is the sensor located? and could it explain my black smoke issue. I will get my son to sit in the boot and film while i boot it on a country road for you guys to see how bad it can be
Old Mar 9, 2016 | 12:50 PM
tfb's Avatar
tfb
nope, still say there is no o2 sensor on a UK diesel 2.5/2.8. Eur spec may be different though.
there is no listing in PAIS for one, no connector info, no wiring diagrams, no provision on ECU for a accepting a signal from one.
EGR is primarily mapped on engine speed and throttle position.
Regards
Ricahrd
