compressor wont engage
Old Aug 28, 2009 | 03:26 PM
dhhbomb's Avatar
Default compressor wont engage
hello all i have a 01 t&c my compressor died so i change it aswell as the reciver dryer and flushed the other parts put it all back together put a vaccum on the system and its holding a vaccum so i go to add freon but its not sucking it out of the can i assume because the clutch isnt kicking on and cannot figure out how to it to kick on and take the freon do i have to bypass the compressor ? any info helps thanks
Old Aug 28, 2009 | 03:32 PM
if u have a vac on the system the can will have enough pressure to at least pull one whole can in with out even using the compressor. as for the power and ground for the compressor U will have power when the pcm want it to have power from the ac compressor relay and it grounds all the time.
check the 15 amp fuse to start with.
Old Aug 28, 2009 | 03:43 PM
dhhbomb's Avatar
ok well i bougt the gauges and vaccum after vaccuming for a 40 min i close the high side and turn off the pump and vaccum stay there so i close low pressure line hook up 134 can it doesnt pull the freon out of the can any idea s on what im doing wrong
i checked the 15 fuse dont know how to check the releay pulled it out didnt look burnt
Old Aug 28, 2009 | 10:35 PM
U know the low side has to be open inorder for the freon to go in.
I think u might be using the setup wrong. Get one of the simple ones where u screw the can into a single line and then attach it to the low side.
Old Aug 29, 2009 | 07:18 PM
dhhbomb's Avatar
that was the problem the ac maniflod directiosn were wrong now i have a new problem i know there is freon in the system and the new compressor keeps cycling on and off ever 30 seconds
Old Aug 29, 2009 | 07:51 PM
thats normal based off high and low side pressure readings. Look on the little blue sticker it will tell how much U need to have in there as well.
gflu
May 6, 2012 11:25 PM
genoaz
Sep 16, 2011 09:10 AM
rastoma
Jun 8, 2011 08:05 PM
mikemonce
Mar 5, 2010 05:12 PM
muttley925
Sep 29, 2008 03:21 AM
