Console panel lights
Old Oct 7, 2018 | 03:58 AM
aare45's Avatar
Default Console panel lights
No lighting in the climate control console panel.
Button lights works and the buttons are working too.
The rest of the cabin lights works.
The fuses are under the hood checked, all ok.
where to look for a mistake?
Chrysler GV 2005 3.3L
Old Oct 8, 2018 | 03:14 AM
Taronga76's Avatar
This is the same on my 2005 Chrysler GV 3.3L...
I assume you can see the temperature reading ok? I can see the temperature on mine.
I will need to power up my 2003 Chrysler GV 2.5 Diesel and check that, as I haven't used it in a while, been meaning to for a while now to check it out but just got use to the Climate panel not lighting up.
Old Oct 8, 2018 | 07:22 AM
aare45's Avatar
Yes everything works, only there is no backlight.
The upper buttons are also lighting missing.
Probably some kind of interruption somewhere., need to have a scheme.
Old Oct 8, 2018 | 07:59 AM
REBEL59's Avatar
I assume the both posters here are not from the NA market. BUT at the age of your vans, the bulbs do burn out and may need reoplacing, did you pull the trim plate and control; panel and check them????
Old Oct 10, 2018 | 12:16 PM
aare45's Avatar
The error must be on the BCM block , plug C4 pin11..?
Old Oct 14, 2018 | 04:56 AM
aare45's Avatar
I removed the battery cord for 2 hours, and now all OK.
GlennDenise
Aug 26, 2018 02:01 PM
adchesney
14
Jan 10, 2015 06:11 PM
Terry1888
Jan 15, 2012 01:52 PM
71grande
May 23, 2010 08:55 PM
Dansauce
Oct 15, 2008 10:13 AM
