Coolant fan relay, 96 Grand Voyager
Fans willnot engage, code 35 hi/lo speed fan circuit. Replaced relay, replaced blown 40 amp fuse. start vehicle, turn on a/c and only drivers side fan engages. Blows 40 amp fuse after ~2 minutes. Has anyone got a fix for this? I suspect a wiring issue to the second(pass. side) fan but not sure how to test.
thanks
thanks
Passenger side fan bearing blown. Dealer would have replaced the fan assembly for $415. I bought an aftermarket assembly from the local parts store for $133 and spent a half day doing it myself. As a short term fix I disconnected the harness from the defective fan to keep from blowing the fuse and keep the vehicle from overheating though it did run hotter than normal.
You can, after disconnecting battery power, reach in and try to turn the fans by hand to isolate which is bad...
speedysp
Aug 7, 2014 03:43 AM
