Coolant fan relay, 96 Grand Voyager
Old Jul 18, 2010 | 10:34 AM
tcx3's Avatar
Default Coolant fan relay, 96 Grand Voyager
Fans willnot engage, code 35 hi/lo speed fan circuit. Replaced relay, replaced blown 40 amp fuse. start vehicle, turn on a/c and only drivers side fan engages. Blows 40 amp fuse after ~2 minutes. Has anyone got a fix for this? I suspect a wiring issue to the second(pass. side) fan but not sure how to test.
thanks
Old Jul 19, 2010 | 12:36 PM
tcx3's Avatar
Default ...and now to the stealership
Took it in to the local 'pros' for $92 diagnostic to isolate the issue. More to follow...
Old Nov 6, 2010 | 11:16 AM
dajoyner's Avatar
Did you ever get this fixed? I am having the same such issues.
Old Nov 7, 2010 | 06:33 AM
tcx3's Avatar
Default Coolant fan fix
Passenger side fan bearing blown. Dealer would have replaced the fan assembly for $415. I bought an aftermarket assembly from the local parts store for $133 and spent a half day doing it myself. As a short term fix I disconnected the harness from the defective fan to keep from blowing the fuse and keep the vehicle from overheating though it did run hotter than normal.
You can, after disconnecting battery power, reach in and try to turn the fans by hand to isolate which is bad...
speedysp
Aug 7, 2014 03:43 AM
jakemary
Apr 11, 2009 11:40 PM
elhtvoh
Sep 23, 2007 12:17 PM
faichu
Feb 20, 2007 07:26 AM
rcorbett
Dec 12, 2006 01:59 AM
