Coolant temps too low.
Old Jan 28, 2012 | 11:14 PM
gr8scott72's Avatar
Default Coolant temps too low.
My coolant temps don't get high enough as I am driving at highway speeds. Once I stop and idle, they slowly creep up. The heater output seems to be affected by this too. Doesn't put out hot hot air, just warm air.
I just changed the water pump, thermostat, and radiator cap. Also flushed the cooling system and put new antifreeze in it.
Did I possibly get a bad thermostat from the parts store?
Also curious, where does the heat for the rear system come from? Is it the same heater core? The rear takes even longer to warm up and at highway speeds, doesn't seem to warm up but just a little.
Old Jan 29, 2012 | 02:15 AM
Raptor 07's Avatar
Model year?
Old Jan 29, 2012 | 07:25 AM
MoparAiken's Avatar
I did see a problem like this a 1970's Dodge Dart. The water pump's impeller was plastic and it lost its grip on the water pump's shaft. The temperature sensor remained cold and the heater didn't work. The coolant in the engine was probably very hot.
They probably don't make water pumps like that anymore, but I hope this helps.
Old Jan 29, 2012 | 08:18 AM
I am going to say an 01 to 06 and broken thermostat
Old Jan 29, 2012 | 09:14 AM
gr8scott72's Avatar
It's an 04 and like I said, I just replaced the thermostat. Maybe I got a bad one.
goggs
Oct 23, 2014 06:49 AM
Dr. Righteous
Jan 21, 2013 07:43 AM
jlampitt
11
Feb 10, 2011 09:56 PM
Josho
Oct 17, 2009 05:08 PM
mn_hokie
Apr 14, 2007 02:06 AM
