Cooling fan issues
Old May 22, 2010 | 06:30 PM
Josho's Avatar
Default Cooling fan issues
Cooling fans packed up on a '98 3.3 V6 Grand Voyager.
I could not get hold of the proper relay so cut and joined on a regular 4 pin relay and connected it all up as it should be and it's not helped.
If I bypass the relay with a bit of wire joining the grey and dark green wires (the thicker two of the four) they spin fine.
However the relay is not turning on.
Now are these relays anything special or does the PCM just send 12V down there thus switching the relay or is it a variable thing? The van got hot enough to go off the scale and the fans didn't hint of life.
Or could it be the PCM? I could hazard a guess on the engine running on 5 cylinders as MPG has been terrible and we're certain it's down on power.
Cheers.
Old May 22, 2010 | 09:33 PM
they are solid state relays go buy one instead of hacking up what U have and nuking a PCM.
Old May 23, 2010 | 02:47 AM
Josho's Avatar
Ahh..
Cheers mate is that a proper Chrysler part or will any SS Relay do because I'm finding it hard to buy a genuine one.
Old May 23, 2010 | 08:59 AM
davet
Apr 1, 2010 11:35 PM
rojo
Mar 22, 2009 09:25 AM
defektivrobot
Apr 22, 2008 12:47 PM
dandiesel
Feb 2, 2007 08:24 PM
Ironside
Jun 10, 2006 01:42 PM
