Cranks but won't start
Old Apr 1, 2017 | 11:43 AM
Rupucis's Avatar
Exclamation Cranks but won't start
So i have 1997. Chrysler Grand Voyager it was all running until i took out engine. When i put the engine back in it now cranks but wont start. we started to seek problem and found out it was that fuel pump doesnt send out further fuel. Any ideas what could cause that?
Old Apr 1, 2017 | 11:45 AM
Rupucis's Avatar
By the way it's diesel
Old Feb 2, 2020 | 10:36 AM
notsofastblue's Avatar
Any news on this?
Old Feb 2, 2020 | 01:21 PM
Are you meaning that the fuel pump, high pressure one that is, is not putting out enough pressure for engine to start.
Being a 1997 variant diesel, still VM though, but possibly mechanical injection. Has your's got separate cylinder heads ?
Old Feb 4, 2020 | 03:35 AM
not taking over, but I have similar problem on my '01 TD, checked # 1 injector and it has fuel. is it possible to have fuel and not fire?
Old Feb 4, 2020 | 02:51 PM
Yes got to have fuel but fuel has to be at a determined pressure. Any leaks will not give you that pressure so ECU is told this and decides not to allow a start.
Old Feb 5, 2020 | 03:32 AM
How does the ECU stop ignition, since this is a diesel?
Doesn't it just control the injection pump?
I had injection pump recently rebuilt..., (this one is electronically controlled).
Where is the ECU located?
Also noticed that hose from intake to turbo had major rupture.
What is the sensor attached doing? is it an air mass flow meter?
Removed the hose.
'Fingered' turbo and it rotates - just guessing if part of the hose is obstructing some valve.
Where to start? testing injectors?
Cranks normally with normal sound, but no start,,,
Thank you for your help...
Old Feb 6, 2020 | 04:15 AM
Now checking TIPM/injection control...
Aware this is a major issue with later models.
www.carcomplaints.com
www.verticalvisions.com
will keep the thread alive and would appreciate your contributions
Tks.
John D'Araneo
Jan 16, 2020 08:16 AM
p0z3r
Mar 25, 2017 10:04 PM
Deefer
Jun 3, 2014 07:12 AM
cindy121087
Mar 21, 2012 01:34 AM
darlon
Apr 19, 2010 06:19 PM
