Crankshaft Sensor
Old Jul 13, 2007 | 09:02 AM
rwcrazy's Avatar
Default Crankshaft Sensor
I have to replace my crankshaft sensor and I unscrewed the one that is in there, but cannot get it out?
The bracket for the Alt is in the way, is there a certian way to remove this, without taking everything apart?
I have a 1997 3.8 T & C
Thanks for any help
Old Jul 13, 2007 | 10:34 AM
Default RE: Crankshaft Sensor
U mean CAMSHAFT sensor the crank sensor is on the tranny on the other side of the engine where the alt is at. U pretty much haft to take off what ever u need to inorder for u to get assess to what u are doing.
Old Jul 13, 2007 | 06:56 PM
rwcrazy's Avatar
sorry, a mechanic said it was the crankshaft sensor, unless that is somewhere else on the engine?
Old Jul 13, 2007 | 06:59 PM
so which one do u need then cam or crank??? if u dont know just replace both of them. They go hand in hand with opperation of the engine
Old Jul 13, 2007 | 07:04 PM
rwcrazy's Avatar
he told me i needed the crankshaft sensor,
here is what happens, I can be driving and it will just die, sometimes I can pop it un N and restart it and it will go, sometimes I need to stop and restart it
sometimes it will do it when i stop aty a stop sign, but i guess according to the codes the mechanic said i needed the crankshaft one
thanks
Old Jul 13, 2007 | 09:00 PM
ok the crank shaft sensor is on the tranny on the driver side below and behind the intake. here is a pic. Make sure u have a green dot spacer on the sensor head or u will not get teh correct clearence and snap the sensor or make it not read right and no start.
[IMG]local://upfiles/1033/E1483C52372E47E8A0D3CF35FBB4F311.gif[/IMG]
Old Jul 20, 2007 | 01:30 PM
iliescu_l's Avatar
i had the same problem...i had to replace both camand crank ....
IAHCross
Dec 16, 2009 05:24 AM
96RedLXI
Jul 19, 2008 08:38 AM
funjon1
Jun 25, 2008 07:01 PM
mialena
Cirrus & Breeze
Apr 23, 2008 07:23 AM
polancopower
Cirrus & Breeze
Dec 13, 2007 10:25 AM
