Cruise control going crazy!
Old Nov 1, 2014 | 09:57 AM
eginther's Avatar
Default Cruise control going crazy!
We just drove our 00 town and country limited 5 hours from Houston to dfw and during the trip I set the cruise control between 75 and 80. When I tapped the brake to disengage the cruise control it wouldn't. I ended up having to put the van in neutral to disengage the cruise. Another time, I hit the resume button and it passed the speed I had previously set it at and kept accelerating. I need to find a troubleshoot for this as we are driving 17 hours at the end of the month. Thanks for the help.
Old Nov 1, 2014 | 03:58 PM
System Reboot....
Old Nov 3, 2014 | 10:50 AM
eginther's Avatar
Please explain how to system reboot...
Old Nov 3, 2014 | 01:52 PM
Remove neg battery terminal for 30 mins and while its off clean the connecting parts. Screw it down, back forwards on refit.
Have you got a good battery and is Alternator charging ok...
We'll get you learned on here.
And think Safety.
Old Nov 4, 2014 | 08:27 AM
eginther's Avatar
Alt and battery are good to go. I'll give it a try!
Old Nov 4, 2014 | 01:19 PM
Gives report...
Old Nov 5, 2014 | 08:10 AM
eginther's Avatar
Reset the computer and now the cruise control won't even turn on. Any thoughts?...
Old Nov 5, 2014 | 03:32 PM
You got an ABS light up on dash by any chance. Or flickering.
If not this is getting tricky.
Try key dance for faults but relating, likely not to be shown.
Is this a Clock Spring issue here guys as switches are on Steering Wheel...
Await Tech Electro-Sparks...
Old Nov 5, 2014 | 10:45 PM
eginther's Avatar
So last night the cruise control wouldn't even turn on and this morning it turned on and is still exhibiting the same symptoms. At a loss...I'm pretty mechanically inclined but I don't even know what to test or replace?
Old Nov 6, 2014 | 03:16 PM
Looks like your looking for a bad connection. Go back the threads in relation to Cruise control and Clock Spring.
