Cylinder 1 Misfire help
Old Aug 20, 2016 | 05:28 PM
leclaire808's Avatar
Default Cylinder 1 Misfire help
My 2011 Town and Country stalled out two days ago and I can't keep it running. ODB code says Cylinder 1 Misfire. The Electronic Throttle Control light is on as well as the check engine light. It won't idle unless it's above 3k rpm and anything below it sputters and dies. I replaced Cylinder 1 spark plug and coil pack. I also swapped Cylinder 1 fuel injector with Cylinder 3's fuel injector. No change in performance or code. So what else could it be?
Old Aug 20, 2016 | 05:47 PM
05sebringconv's Avatar
if you've ruled out a bad fuel injector and the spark plug and coil....
( I'm assuming that engine has no plug wires and the coil mounted directly on plug, if not could be bad wires )
bad wiring to fuel injector
intake manifold leak
burnt valve(s)
blown head gasket
low cylinder compression
faulty ECM
verify your fuel injector wiring to that cylinder is okay , this can be done with a volt meter
If above checks out, do a compression test on the engine
Old Aug 21, 2016 | 02:28 PM
Does the coil pack come with the lead and plug connector fitted, if it doesn't change them. A damaged lead causes a misfire that's hard to trace.
rComplex
Dec 21, 2014 01:01 PM
Johnny_Sebring
May 13, 2011 07:21 AM
cjhstang
Sep 18, 2009 10:52 AM
optimusprimer
Jul 23, 2009 10:33 PM
irdaneel
Apr 16, 2008 04:12 PM
